Opening a Web Pinpoint Graphic on logon
  • Opening a Web Pinpoint Graphic on logon
  • PaulFr
    PaulFr
‎2018-09-06 12:55 PM
When a User logs on to Cyberstation a Graphic can be added to a User to open at logon, can this be done for webClient?
Cyberstation webClient
The Graphic selected in a User opens on Cyberstation, but does not through webClient logon.
In the User configuration/ Security tab there is a "Default Web Object" field.
Select the required graphic panel in this field and when you log on through a webClient browser session this graphic will automatically open.
  • 6888
