On a Xenta 301 controller, what is the 0-10v output impedance?
  • On a Xenta 301 controller, what is the 0-10v output impedance?
‎2018-09-06 03:17 PM
Xenta 301 programmable controller
Electric characteristics of the controller can be used to determine if field devices are compatible.
The 0-10v output impedance is approximately 50 ohm, and in the datasheet it supplies maximum 2 mA.
Tags (2)
  • 1507
  • volt
