On a Windows 7 PC, when right-clicking on an object, both its "override" and "set" pop-up boxes do not fully open in Niagara G3 versions 3.5.x and older.
  • On a Windows 7 PC, when right-clicking on an object, both its "override" and "set" pop-up boxes do not fully open in Niagara ...
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 12:18 PM
An object’s override and set pop-up boxes do not fully open in Niagara G3. You have to grab and pull the corner of the pop-up to open it completely. Niagara version 3.5.x is installed on a Windows 7 PC.
Niagara G3 Version 3.5.x and older
Versions of WorkBench prior to 3.6.31 have not been officially certified with Windows 7.
The issue is more of a nuisance, but does not affect functionality in any way.
There are a couple of options you can try to try and correct the issue.
The first option is to try to reduce the font size in Windows 7.
- Click on the Start button and open the Control Panel
- Open the Fonts folder and select Change font size.
- Select smaller fro the font size and click apply
The other option is to change the screen resolution slightly.
Note: Since Niagara versions prior to 3.6.31 have not been certified for the Windows 7 operating environment, the above my not correct the issue.
  • TAC IA Series
  • 8021
