On a MNL-800 controller, are resistors required on the universal inputs when wired for pulse counting?
  • On a MNL-800 controller, are resistors required on the universal inputs when wired for pulse counting?
  • sesa119747
    sesa119747
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 02:54 PM
MNL-800 controller
Knowing the resistor requirement helps implementing pulse count using universal inputs.
UI1 does not require an external resistor. If using UI2 through UI8 as a pulse input, an external 10K resistor to +5.1 V is required.
  • TAC IA Series
  • 2768
