On a DMS installation, why does a controller listed as "SAI", in OPRIF, not appear as a Microsmart controller?
  • On a DMS installation, why does a controller listed as "SAI", in OPRIF, not appear as a Microsmart controller?
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-10 04:09 AM
A DMS installation has nine controllers communicating properly.  However, only eight of them are listed as Microsmart controllers.  The ninth is identified in OPRIF as a "SAI" controller.  The DMS points for the SAI controller are updating with no issues.  How can its database be saved?
DMS (all revisions)
n/a
The SAI controller was one of the first generation controllers developed for use with the DMS product line. It is referred to as a Slave AI Module. The old part number is N604-003 which may appear on a sticker somewhere on the controller itself. It takes six analog inputs.
These controllers were installed with revision 8 firmware. On the printed circuit board, there will be an IC labeled with 8.x.
The key to this controller is that it is NOT smart. It does not take a database. The Analog Input points MUST be created in the DMS. That's why it shows up as one of nine controllers but does not show up as a Microsmart controller.  There's no need to back up its database since it doesn't take one.
Click here to view a figure of the Slave AI (SAI) Module.
  • TAC IA Series
  • 6416
