Objects have become edit locked and can not be unlocked
  • Objects have become edit locked and can not be unlocked
  • Dave_Shore
    Dave_Shore
  • sesa139513
    sesa139513
‎2018-09-06 10:18 AM
Property unlock, CTRL-U and "Object editlock=false" do not unlock the object.
The Plain English Integrated Development Environment may crash
Andover Continuum
SQL Server Database
The hard disk on the SQL server has no more space
Stand Alone database may have reached its limit
Once the hard disk on the SQL server PC is too full, Continuum can no longer write to the SQL database, thus object can become editlocked.
Space on the hard disk needs to be released, it is likely that old backups have filled the hard disk up.
Backups should be moved to a different hard disk
If a Stand Alone install, MSDE (SQL2000) has a 2GB limit (up to v1.81), SQL2005Express has a 4GB limit (v1.82 and after)
NOTES
  • The database may go to Status "In recovery" until space is made on the hard disk, this may also cause CyberStations to loose contact with the database.
  • It may note be possible to edit or create new objects when in this mode (database or hard disk full)
Tags (2)
  • 13592
  • big
