OSTART and OSTOP not working on a temperature control extension
  • OSTART and OSTOP not working on a temperature control extension
‎2018-09-06 03:23 PM
I/NET Resident I/O
Temperature Control Extension
Optimal start requires the space temperature to meet the cooling/heating target temperature sometime after the optimized start time.
Check that the space temperature has met the cooling/heating target temperature sometime after the optimized start time in order for the OSTART to work properly.
  • TAC INET
  • 1268
