Not Possible to Open Projects in PCT – "/var/pct" Partition at 100%
  • Not Possible to Open Projects in PCT – "/var/pct" Partition at 100%
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2025-09-10 12:17 AM
Projects fail to open in PCT. When checking the Diagnostics tab, the "/var/pct" partition is shown as 100% full.
Building Operation Project Configuration Tool (PCT)
Accumulation of Server backup files can consume all available disk space in the "/var/pct" partition.
🔍 Note: Starting from PCT version 2.2.1, a warning is displayed when disk usage approaches full capacity.
  • For PCT version 2.2.1 and later:
    • Use the “Free up disc space” command available in the Diagnostics tab to automatically clean up unnecessary files.Free disc.jpg
    • Or if it is not possible to get to the home page for PCT use the "Free up disc space" button here
  • For earlier versions of PCT:
    • Manual cleanup is required.
    • Please contact Product Support for assistance. Cleanup must be performed by R&D.
Additional Recommendations
  • Regularly monitor disk usage via the Diagnostics tab.
  • Periodic cleanup old server backups to prevent recurrence.
  • Consider upgrading to the latest version of PCT to benefit from built-in disk management tools.
  • JonasBrissman25
