No response from access server invalid attempt event
  • No response from access server invalid attempt event
  • AbeMeran
    AbeMeran
‎2018-09-06 02:16 PM
Random no response from access server invalid attempt events showing up in event view
Cyber 1.74 SP2
CX9900
Network issues (router offline) preventing remote validation attempts from reaching the access server
Make sure all routers are online.
The may be an IP conflict with the controller. Disconnected the Lan cable from the controller and ping the controller IP, if there is a response then another device has that same IP.
  • 4367
100% helpful (1/1)
