No IP traffic from Automation Server
  • No IP traffic from Automation Server
  • MikaelKrantz
    MikaelKrantz
Guinan MikaelKrantz Guinan
‎2023-04-13 04:37 PM
Last Updated: Administrator CraigEl Administrator ‎2023-04-26 11:53 PM
Automation Servers are being connected to an IT managed network. The network requires that devices broadcast their MAC address in order to be added to the network switch. Automation Servers are not broadcasting their MAC address to the switch  and cannot be added to the network
EcoStruxure Building Operation.
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
A stand alone AS-P server with a fixed IP address does not send out anything on the IP network.
If you need the AS-P server to send out some traffic, you could define an NTP server that generates traffic when synchronizing the time.
  • MikaelKrantz23
