Niagara R2 UNC installed on a residential ISP network using dynamic IP addressing
  • Niagara R2 UNC installed on a residential ISP network using dynamic IP addressing
  • mroche1
    mroche1
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-11 01:48 PM
Last Updated: Lt. Commander mroche1 Lt. Commander ‎2021-12-14 02:11 PM
A Niagara R2 UNC is installed in a remote location with internet service provided by Comcast. Until now, a static IP address was provided by Comcast allowing for a static IP address to be provided to the UNC. Comcast has now switched to dynamically assigned IP addresses. Each time the installed internet router is power-cycled, it will receive a different IP address. Can the UNC be enabled to support DHCP and continue to be remotely accessible?
TAC IA Series
Niagara R2
Comcast's changes in internet service policy
Niagara R2 stations support DHCP but the IP address must be 'reserved' within the DHCP server. See the Niagara Networking and Connectivity Guide, page 3-23. In this application, there is no DHCP server. Enabling DHCP will not allow for remote connectivity to continue as it did.
Review the requirements with Comcast to determine if they can provide a solution involving a reserved IP address for the installed router. This will allow the UNC to retain its static IP address and maintain remote connectivity.
Alternatively, dynamic IP addressing can be "out-sourced" to a 3rd party company. See the Niagara Networking and Connectivity Guide, page 5-22. The company TZO and its website www.tzo.com has changed to www.dyn.com and their most often-used product is dyndns-pro (http://dyn.com/dns/dyndns-pro). There is a small annual service fee but it has worked successfully with Niagara R2 applications.
There is also a free version available at http://free.domain.name/en.html?domain=dyndns-home.com.
  • TAC IA Series
  • 11873
