Niagara NTP Troubleshooting
Select a Country
  • Niagara NTP Troubleshooting
  • RandyDavis
    RandyDavis
RandyDavis Champion
‎2024-10-15 09:32 AM
Configuring NTP and troubleshooting in the Niagara Frameworks
TAC IA Series
  • I/A Series N4 Enterprise Server
  • I/A Series N4 Jace
Guide to configure and test NTP server and Jace sync operations
Please familiarize yourself with the official documentation of the NTP functionality. NTP and its configuration are comprehensively documented in the Niagara Platform Document. The official documentation is updated frequently and may contain information that supersedes the content of this article.
Using the ntpq utility program
The NTP Project maintains the NTP software that is compiled and included with Red Hat Enterprise Linux (and other most other Linux distributions). To get the software for Microsoft Windows, Meinberg ports the software and provides it. With this software, you not only get the ntpq utility program, you also can run the NTP client/server on your PC. In this way, you can use your PC as an NTP time server to your JACE.
  • NOTE: The Client and Server (Time Only) options were added in 4.9. Using Server creates potential attack surface for 'Mode 6' queries. But to query with ntpq as described below, it must be set to Server, at least temporarily. Be advised that you should not have your JACE exposed to the Internet. Consult the Niagara Cyber Defense page for more details.
Using the ntpq utility program, you can query a JACE that is configured for NTP, and get a list of the peers known to the JACE and a summary of their state. For this use the -p option, and provide the IP address to the JACE. The command will look like this:
  • ntpq -p 192.168.1.140
    The output of the command will look something like this:
    The ntpq man page at ntp.org fully documents the details of the table above. Only a few details will be covered here.
  • The row that begins with * (asterisk), has been declared the system peer.
  • The second row begins with a space, indicating that it is an unreachable peer.
  • The third column is for the stratum. Stratum 0 is an actual time source, like an atomic clock, that provides time to a stratum 1 NTP server. A stratum 2 server gets its time from a stratum 1 server. A stratum 3 server gets its time from a stratum 2 server, and so on.
  • Reach is a circular log buffer containing a set of eight bit-flags, expressed as an octal number. Convert octal to binary to determine the reach for the last eight attempts. For example, 376 converts to 11111110, which means that we failed to reach the server the last time, but the other 7 were successful.
Using the NtpPlatformServiceQnx spy page
  1. Right-click the NtpPlatformServiceQnx and select Views > SpyRemote.
  2. As you scroll down the first section of interest is the one that shows the NTP Configuration File. It reads what we've written to the file ntp.conf and displays it.
    #/home/niagara/etc/ntp.conf: Niagara Network Time Protocol Configuration File
    #Use the NtpPlatformService UI to modify this file.
    #Created: 24-Sep-19 4:53 PM EDT
    #Niagara NtpPlatformService variable, do not modify
    #ntpEnabled true
    #syncAtBoot true
    #server list
    server 192.168.1.2 burst prefer
    server 192.168.1.3 burst
    server 192.168.1.4 burst
    peer 192.168.1.5
    peer 192.168.1.6
    #ntp features enabled
    enable ntp stats
    #ntp panic value, if offset exceeds this, ntpd should exit (disabled if 0)
    tinker panic 0
    #gather information about statistics
    statistics clockstats loopstats
    filegen clockstats file clockstats type none nolink enable
    filegen loopstats file loopstats type none nolink enable
  3. The next section of interest is for the NTP Daemon Log. You'll only see this section if Generate NTP Statistics is set to true. It's generally not necessary to consider these statistics.
    Jan 30 08:45:14 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd1553.126c40f0 does not match aorg 0000000000.00000000 from sym_active@172.16.10.197 xmt 0xe1dd161a.aa0c9b85
    Jan 30 08:46:14 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd1552.126c471e does not match aorg 0000000000.00000000 from sym_active@172.16.10.99 xmt 0xe1dd1656.2b9be356
    Jan 30 08:46:18 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd1553.126c40f0 does not match aorg 0000000000.00000000 from sym_active@172.16.10.197 xmt 0xe1dd165a.aa0c9453
    Jan 30 08:47:18 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd1552.126c471e does not match aorg 0000000000.00000000 from sym_active@172.16.10.99 xmt 0xe1dd1696.2b9bca8b
    Jan 30 08:47:22 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd1553.126c40f0 does not match aorg 0000000000.00000000 from sym_active@172.16.10.197 xmt 0xe1dd169a.aa4e33f0
    Jan 30 08:48:22 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd1552.126c471e does not match aorg 0000000000.00000000 from sym_active@172.16.10.99 xmt 0xe1dd16d6.2b9bd269
    Jan 30 08:48:29 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd1553.126c40f0 does not match aorg 0000000000.00000000 from sym_active@172.16.10.197 xmt 0xe1dd16dd.aa8fa9b9
    Jan 30 08:49:27 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd1552.126c471e does not match aorg 0000000000.00000000 from sym_active@172.16.10.99 xmt 0xe1dd1717.2b9bcbe9
    Jan 30 08:49:34 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd1553.126c40f0 does not match aorg 0000000000.00000000 from sym_active@172.16.10.197 xmt 0xe1dd171e.aad12b7e
    Jan 30 08:51:18 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd1203.21caf133 does not match aorg 0xe1dd175e.153d05cf from sym_active@172.16.11.205 xmt 0xe1dd1786.c4cb59c2
    Jan 30 08:51:33 nto ntpd[8740900-1]: receive: Unexpected origin timestamp 0xe1dd11bb.218961dc does not match aorg 0xe1dd175c.153d0991 from sym_active@172.16.10.171 xmt 0xe1dd1795.1de9a94c
    Jan 30 08:51:40 nto ntpd[8740900-1]: receive: KoD packet from 172.16.10.158 has a zero org or rec timestamp. Ignoring.
    Jan 30 08:52:44 nto ntpd[8740900-1]: receive: KoD packet from 172.16.10.158 has a zero org or rec timestamp. Ignoring.
  4. The next section is NTP Daemon Drift. After NTP has synchronized with reliable time servers for a significant amount of time, it will write the calculated drift (in PPM) to a file, such that it can initialize with this value on reboot. It will use this calculation of how far the clock drifts, to correct the clock in real-time, in increments too small for any application to detect.
    NTP Daemon Drift
    20.185
  5. NTP Daemon Clock Stats is next. It reads what is in the clockstats file. In this example output, the file does not exist and the spy page tells us so.
    Modified Julian Day | Secs. Past UTC Midnight | Clock Address | Last Time Code
    Error reading /var/run/ntpdstats/clockstats: /var/run/ntpdstats/clockstats (No such file or directory)
  6. The final section of interest is NTP Daemon Loop Stats. If you're not getting data here, then the configured servers/peers might not be reachable.
    Modified Julian Day | Secs. Past UTC Midnight | Time Offset Secs. | Drift Compensation | Estimated Error | Stability | Polling Interval
    58860 29871.775 0.000000000 20.226 0.000976563 0.000000 6
    58860 30081.780 0.000753215 20.226 0.000976563 0.000000 6
    58860 30150.781 0.000753034 20.226 0.000976563 0.000000 6
    58860 30688.793 0.000018819 20.227 0.000976563 0.000213 6
    58860 31155.803 -0.000220479 20.220 0.000976563 0.002179 6
    58860 31221.804 0.002128888 20.229 0.001234668 0.003595 6
    58860 31233.872 -0.001539013 20.228 0.001736532 0.003385 6
    58860 31385.925 -0.000336908 20.225 0.001679057 0.003345 6
    58860 31498.941 0.000431773 20.228 0.001608116 0.003294 7
    58860 31841.815 0.000467697 20.230 0.001543370 0.003195 7
    58860 32276.675 0.000795988 20.235 0.001484403 0.003499 7
    58860 32546.942 0.009518751 20.274 0.003382136 0.013979 7
    58860 32666.611 0.000412569 20.274 0.004513791 0.013078 7
  • TAC IA Series
  • RandyDavis24
100% helpful (1/1)
