Niagara G3 station graphics browser error: Root element must be "nav"
  • Niagara G3 station graphics browser error: Root element must be "nav"
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-11 01:56 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-08-13 06:57 AM
In a Niagara G3 station, whenever someone logs into the graphics (with any web browser), the following error appears in the application director output:
javax.baja.xml.XException: Root element must be "nav" [line 3]
 at javax.baja.nav.NavFileDecoder.err(NavFileDecoder.java)
 at javax.baja.nav.NavFileDecoder.decodeDocument(NavFileDecoder.java)
 at javax.baja.nav.NavFileDecoder.load(NavFileDecoder.java)
 at javax.baja.user.BUser.getHomePage(BUser.java)
 at com.tridium.fox.sys.user.BUserChannel.fetchPrefs(BUserChannel.java)
 at com.tridium.fox.sys.user.BUserChannel.process(BUserChannel.java)
 at com.tridium.fox.sys.BFoxConnection.process(BFoxConnection.java)
 at com.tridium.fox.session.SessionDispatcher.dispatch(SessionDispatcher.java)
 at com.tridium.fox.session.SessionDispatcher.run(SessionDispatcher.java)
 at java.lang.Thread.run(Unknown Source)
TAC IA Series
Niagara G3
The G3 user account has the nav file property pointed to a file that is not a nav file.
Correct the nav file property setting.
  • TAC IA Series
  • 11942
