Niagara Can Fail to Launch on Windows If Updated Visual C++ Redistributables Are Not Present
  • Niagara Can Fail to Launch on Windows If Updated Visual C++ Redistributables Are Not Present
  • RandyDavis
    RandyDavis
Guinan RandyDavis Guinan
‎2023-11-07 12:53 PM
on ‎2023-11-07 12:53 PM
Error message in Platform Application Director;
SEVERE [00:25:32 08-Feb-21 EST][sys] Cannot boot
TAC IA Series
  • I/A Series N4.9 and later
  • I/A Series N4 Enterprise Server
  • I/A Series N4 WorkBench
In 4.9.1.30 and later, the JDK distributed with Niagara was upgraded to 8u271.
Starting in JDK 8u261, the target Visual C++ version was changed. While the updated libraries are available in the jre/bin folder, this folder is not on the PATH for NRE binaries. This can cause Niagara to fail to launch on Windows if another copy of the Visual C++ Redistributables is not present.
Install the Visual C++ 2017 Redistributables.
https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads
At the time of this article, Microsoft packages the 2015, 2017, & 2019 redistributables together.
Select and install the x64 version.      https://aka.ms/vs/17/release/vc_redist.x64.exe
  • TAC IA Series
  • RandyDavis23
