Network modem object settings for alarm delay and dial parameters windows
  • Network modem object settings for alarm delay and dial parameters windows
‎2018-09-07 12:00 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-08-27 06:31 AM
Within the Network modem object, what settings are required/normal for both the alarm delay and dial parameters windows?
TAC Vista
  • Xenta 901
  • Vista
  • Modem
  • Manual
Problem/tip using modem dial
This depends on the desired functionality. One examples definitions for the TAC Xenta:
  • Dial when priority 1 alarms have been tripped/reset/acked
  • Dial when priority 2 alarms have been tripped/reset
  • Dial remaining alarms only once per day when it is cheaper to dial
It always depends on the site requirements. One recommendation is to use at least 5 minutes delay before dial up.
Please read the TAC Xenta 901 Handbook.
  • 1400
