Netcontroller 9680 installed and no access events report
  • Netcontroller 9680 installed and no access events report
  • Carl_Slack
    Carl_Slack
‎2018-09-06 01:48 PM
A CX 9680 Netcontroller II does not provide access events to Cyberstation 1.80
Continuum Cyberstation 1.80
Incorrect firmware version
Continuum Cyberstations versions 1.74 sp2 through 1.81,  CX 9680 controllers will need to be at firmware version 2.000xxx
Continuum Cyberstations versions 1.82 through 1.9x,  CX 9680 controllers will need to be at firmware version 2.100xxx
NOTE: Controllers are shipped with the latest firmware versions. If you are using Continuum Cyberstation 1.74sp2 - 1.81 you may need to down rev the firmware version.
  • 5219
This is a heading
