Need to replace GCMA-135-2 ASD Repeater board.
  • Need to replace GCMA-135-2 ASD Repeater board.
  • sesa116868
    sesa116868
‎2018-09-06 01:45 PM
The GCMA-135-2 circuit board for the ASD repeater needs to be replaced but the item is not available for purchase.
RPTR-WIRE product, GCMA-152-2 circuit board
Unit needs to be replaced.
The GCMA-135-2 circuit board used in the RPTR-WIRE ASD repeater is not available as a field replaceable part.
Purchase as an assembled unit using part number RPTR-WIRE.
  • TAC IA Series
  • 5298
