NPR loses the program when AC power is Removed
  • NPR loses the program when AC power is Removed
‎2018-09-06 03:27 PM
I/NET
NPR
On Board Battery
You can either:
  • Remove the cover and look at the green colored on board battery. It is located on the right side of the lower board, next to the upper board. Replace this battery
  • Use a UPS power supply to prevent AC power loss
  • Replace the device.
  • TAC INET
  • 1053
