NPR and modems set up for integrated NPR dialing do not pose security risks to a network
  • NPR and modems set up for integrated NPR dialing do not pose security risks to a network
  • sesa139513
    sesa139513
‎2018-09-06 03:13 PM
Can an NPR and modem setup for integrated NPR dial, allow a "back door" into a company's Ethernet lan (i.e. compromising their network security)?
I/NET site
The NPR will not talk to a PC unless it has I/NET running. This eliminates the possibility of using it as a "back door" to bypass network security measures.
  • TAC INET
  • 1677
