NCP network with two or more MicroNet Touchscreens, values in controllers on a sublan are changing unrepentantly.
  • NCP network with two or more MicroNet Touchscreens, values in controllers on a sublan are changing unrepentantly.
  • DavidChild
    DavidChild
  • CraigEl
    CraigEl
  • Gary
    Gary
‎2018-09-07 04:36 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-04 06:27 PM
On an NCP (Network Control Protocol) network with two or more MicroNet Touchscreens, certain values within MicroNet controllers located on the Sub-LAN of a Touchscreen may change unexpectedly and without user intervention.
Satchwell Micronet
Micronet NCP Touchscreens
This issue typically arises due to high communication traffic through the MicroNet Touchscreens. When multiple Touchscreens are present on the same NCP network, the increased data exchange can lead to unintended value changes in connected controllers.
⚠️ Important Notices
  • The MicroNet 50 series controllers (MN350, MN450, MN550, MN650 LCD and Touchscreen) have been withdrawn from sale.
  • The IAC 420, IAC 600, and Touchscreen models have also been discontinued.
  • No direct replacements are currently offered.
For more details, refer to:
  • PA-00495 - Notice of Withdrawal - Satchwell Sigma (PDF)
  • PA-00528 - End of Commercialization - Satchwell Sigma (PDF)
  • Firmware version, MNTS0H, addresses this issue.
  • This firmware has been validated with:
    • VisiSat 2.1 Build 148 Service Pack 1
    • MN50 Series Controllers
    • Xenta 555 and Xenta 731 hardware
  • For detailed firmware information and installation guidance, refer to:
    • TPA-LOND-09-0029.00 – Touchscreen TS0H Firmware (PDF)
  • Satchwell MicroNet
Tags (3)
  • 3520
  • CraigEllis25
  • GaryMontague19
