Multiple instances of SQL
  • Multiple instances of SQL
  • Carl_Slack
    Carl_Slack
‎2018-09-06 01:49 PM
On a city wide network there are several SQL instances to choose from, will this be an issue with Continuum.
Continuum Cyberstation
SQL
Product compatibility with several instances of SQL
Continuum workstations will be setup with the Continuum Database Initialization and all workstations will point to the same SQL instance where the database is created. Having other instances of SQL installed on a network will not cause an issue.
  • 5194
This is a heading
