Mounting MF20/MF40 actuator in 90 degrees position
  • Mounting MF20/MF40 actuator in 90 degrees position
  • SESA150559
    SESA150559
‎2018-09-06 12:14 PM
Is it possible/suitable to mount the MF20 or MF40 actuator in 90 degrees angle out from the valve VF208W?
MF20
MF40
VF208W
In some applications/environments it is hard to fit in the actuator on top of the valve due to space limits.
There should be no problem mounting the actuator / linkage in a 90 degree angle out from the valve.
  • Field Devices
  • 8157
