Modifying the SNMP name or address on an NPR
  • Modifying the SNMP name or address on an NPR
  • sesa139513
    sesa139513
‎2018-09-06 03:14 PM
Can I modify the SNMP name or address on an NPR?
I/NET site
If the customer has an SNMP manager on site and wants to use this function, enter the information he gives you. If not, leave them alone. If the address gets set to 0.0.0.0, you will have communication problems across a commercial router.
  • TAC INET
  • 1615
