Modicon Switch Ordering and RSTP Configuration using EBO with MPX/RPX
  • Modicon Switch Ordering and RSTP Configuration using EBO with MPX/RPX
Admiral Alan_Wood Admiral
‎2022-07-06 08:35 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:52 AM
Modicon Switch Ordering options and how to configure the Ethernet Switch for RSTP for EBO
  • Modicon RSTP Switch (Not Connexium)
  • Building Operation Automation Server Premium
  • MPX and/or RPX Controllers
  • Ethernet Switch Configurator
Schneider Electric Industry Offers an RSTP enabled Ethernet Switch that can be used with EBO instead of 3rd party Switches
The following video will illustrate the following steps for Ordering and installing the Modicon Ethernet Switch with EBO
  • The Modicon Connexium Ethernet Switch has been replaced by the updated Modicon Switch
  • Modicon Switch Part Numbers and Email address for ordering
  • Connect and use the SE Ethernet Switch Configurator executable for Switch configuration
  • Set the Time and use the Syslog for troubleshooting
  • Configure EBO and the controllers (MPX/RPX) for RSTP
  • Test the Modicon Switch, EBO, and the MPX/RPX controllers for RSTP
Related Links:
  • Modicon Switch Part Numbers and Ordering Information - (see attached Part Number slide)
  • MCSESM Switch Installation Manual
  • MCSESM Switch Configuration Manual
  • Ethernet Switch Configurator Software - look for  SchneiderElectricEthernetSwitchConfigurator2303_Wi...
  • Other Modicon Switch documents
  • RSTP Troubleshooting Community Thread
  • TGML Graphic Setup Video (Training Department)
SchneiderElectricEthernetSwitchConfigurator2303_windows_x86.zip
Tags (2)
  • AlanWood22
  • AlanWood24
100% helpful (3/3)
