Modems fail to connect with the USRobotics 5686 series V.92 modems
  • Modems fail to connect with the USRobotics 5686 series V.92 modems
  • SESA113595
    SESA113595
‎2018-09-06 02:57 PM
Some older modems will successfully connect with the USRobotics 5686 series V.92 modems on the first call, but will fail to connect on subsequent attempts.
TAC IA Series
The V.92 protocol must be disabled when using these modems with older modems.
To disable the V.92 protocol on the USRobotics 5686 series modems, enter the following setup string in addition to the string specified in the referenced bulletin, before saving the settings:
AT +PIG=1 +PMH=1 +PQC=3
  • TAC IA Series
  • 2668
100% helpful (1/1)
