Modem Settings registry key in the Windows 95/98 Registry
  • Modem Settings registry key in the Windows 95/98 Registry
‎2018-09-06 03:30 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-10-07 08:27 AM
Where is the Modem Settings registry key in the Windows 95/98 Registry?
TAC INET
  • Windows 95
  • Windows 98
Modifications to modem settings must be performed in the registry editor.
  1. Open the Registry Editor (Start > Run > regedit)
  2. Navigate to:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Class\Modem\xxxx\Settings
  • TAC INET
  • 903
