Modbus TCP Integration with ATV600
  • Modbus TCP Integration with ATV600
  • Katha
    Katha
Lt. Commander Katha Lt. Commander
‎2025-10-21 07:40 PM
on ‎2025-10-21 07:40 PM
Reading registers from an ATV600 via Modbus TCP in EcoStruxure Building Operation (EBO)
  • Building Operation Automation Server
  • Modbus
Users may need to access and monitor data from an ATV600 drive using Modbus TCP but require guidance on configuration steps and tools.
Step 1: Download Required Tools
  • SoMove: Software for configuring ATV600
    Download SoMove
  • DTM Library for ATV600: Install the correct model
    Download ATV6xx DTM Library
Step 2: Configure Password
  • The default password for ATV600 is in the manual.
  • Change the password via the device menu 8.7 or through a web browser.
    How do I access the embedded web page on an ATV630 drive? | Schneider Electric USA
Step 3: Log In and Configure IO Mapping
  • Use the DTM tool to log in to the device.
  • Navigate to IO Mapping.
  • Add the register table according to your requirements.
Step 4: Configure Workstation
  • Protocol: Modbus TCP
  • Device ID: 255 (for logical register mapping).
  • Create points in Workstation and enter CHANNEL information based on the IO mapping list.
Example:
  • In DTM: CHANNEL 1 corresponds to register number 3203.
  • In Workstation: Enter 1 to access the logical register map.
✅ Tip: Always verify that register addresses in Workstation match the IO mapping in ATV600.
  • KatharineVasquez25
