Modbus Protocol Information
  • Modbus Protocol Information
‎2018-09-10 01:26 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:51 AM
What resources are available to get more information on the Modbus protocol?
Andover Continuum,EcoStruxure Building Operation,Field Devices,Satchwell BAS & Sigma,Satchwell MicroNet,TAC IA Series,TAC INET,TAC Vista
Modbus ASCII/RTU
Modbus TCP/IP
The Modbus protocol information is available on www.modbus.org
Use the menu on the left and select Technical Resources. Select the Modbus Specifications.
Found on www.modbus.org are the protocol specifications:
Modbus ASCII/RTU
Modbus TCP
Labels (8)
  • Field Devices
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
Tags (3)
  • 5548
  • GaryMontague22
  • PeterLarsen22
0% helpful (0/1)
