Modbus Network Offline Alarm in EBO Version 6 and Later
  • Modbus Network Offline Alarm in EBO Version 6 and Later
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2025-10-21 04:24 PM
on ‎2025-10-21 04:24 PM
In EcoStruxure Building Operation (EBO) version 6 and later, users may encounter a persistent Modbus Network Offline alarm, even when all Modbus devices under the network are online.
  • Building Operation Automation Server Premium(AS-P)
  • Building Operation Automation Server Bundled (AS-B)
The Modbus communication architecture was restructured between EBO versions 5 and 6.
  • In EBO version 5, the system could generate alarms for the Modbus network itself being offline.
  • In EBO version 6 and later, network-level offline alarms are deprecated. Alarms are now only generated at the device level, not for the network.
If a site is upgraded from version 5 to 6, any existing Modbus network offline alarms will persist, but EBO will no longer monitor or clear them, as it no longer tracks network-level status.
 To remove the obsolete Modbus network offline alarm in EBO version 6, you have two options:
  1. Hide the Alarm
    • Since the alarm is no longer relevant in version 6, you can simply suppress or hide it from the alarm list.
  2. Delete and Recreate the Modbus Network
    • This method ensures complete removal of the alarm. Important: Ensure you have a verified backup before performing these steps:
      • Export the Modbus network configuration.
      • Delete the network using the “Keep Bindings” option.
      • Re-import the network configuration.
  • JonasBrissman25
