Minimum display is 1024x768 which is too small for proper screen size
  • Minimum display is 1024x768 which is too small for proper screen size
  • sesa139513
    sesa139513
‎2018-09-10 11:08 PM
SmartStruxure up to release 1.3
Release notes for 1.3 in 9.2.1 state the Minimum display is 1024x768 which is too small for proper screen size.
In the screen capture below, a simple schedule is created, and then a New Schedule Event is selected which opens the window. the window is larger than the screen size, missing the top and bottom.
Adjust the screen resolution to a larger size which is suitable. Size is dependent on hardware specifications.
Tags (4)
  • 11974
  • 20272
  • alm
  • defect
