Microsoft Error Codes
  • Microsoft Error Codes
  • SESA116857
    SESA116857
‎2018-09-07 07:57 AM
Review of Windows event log, product event logs, or error windows during operation provides an error code number that is unreadable.
Microsoft Windows
Microsoft uses a standard list of error codes which programs can access. The display of these errors is typically in a decimal or hexadecimal format.
Use the Windows Error Codes spreadsheet which allows the user to enter the code as either Hexadecimal or Decimal format and provide the text description for the error code. Use the error code description to further diagnose the problems being experienced.
Guidance on whether a code is Hexadecimal or Decimal:
0x00000001 - Hexadecimal
-214000000 - Decimal
Labels (7)
  • Field Devices
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
Windows Error Codes.zip
  • 4798
