Merging Sigma Lookup Tables Across Multiple Sites
  • Merging Sigma Lookup Tables Across Multiple Sites
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • Gary
    Gary
‎2018-09-11 08:54 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-10 08:50 PM
There are no built-in tools or utilities available in Sigma to merge lookup table files from multiple sites into a single unified file.
Satchwell BAS & Sigma
Satchwell Sigma
When consolidating multiple Sigma sites into one, each site may have its own set of lookup tables. Sigma does not provide a native method to merge these tables, requiring manual intervention to avoid data loss or corruption.
To manually merge lookup tables from multiple Sigma sites:
  1. Export Lookup Tables from Each Site
    • Open the lookup tables for Site 2, 3, 4, etc.
    • Use the Copy button to copy the data from each required table.
  2. Use a Text Editor
    • Paste the copied data into a text editor (e.g., Notepad).
    • Repeat for all tables from each site.
  3. Prepare the Final Lookup Table File
    • Open the lookup table for Site 1 (the target site).
    • Create a new table for each merged entry.
    • Copy and paste the data from the text editor into the new table.
  • Important Formatting Notes
    • Start pasting from a vacant line below the last entry to ensure the final line is imported correctly.
    • Avoid blank lines above the data, as this can corrupt the top field.
  • Resolve Conflicts
    • If any tables have conflicting lookup table numbers, assign a new number.
    • Update all associated points to reference the new lookup table number.
  • Satchwell BAS & Sigma
Tags (2)
  • 17698
  • CraigEllis25
