Menta macro examples for use with Structured SNVT Types
  • Menta macro examples for use with Structured SNVT Types
  • Sacco
    Sacco
‎2018-09-06 02:52 PM
Last Updated: Administrator DavidFisher Administrator ‎2019-08-09 07:37 AM
Need an example of how to input or output a particular Structured SNVT type in Menta.
TAC Vista
  • Menta macro block library
  • SNVTs
Structured SNVTs use several Member variables to create the SNVT.
Complete macro blocks (FDB or .AUT files) for many of the structured SNVTs exist in the TAC Macro block library. Access the Library:
  1. Select menu item File > Open
  2. Browse to /TAC Menta/Library/Macro Block Library/Miscellaneous/SNVT., filetype= .FBD (.AUT).
  3. Alternatively, right click in your Menta app and select "Load Macro Block" and follow the path above.
This Macro block Library has complete examples of how each Structured SNVT is to be configured, showing the units and types of I/O needed for each SNVT.
Tags (4)
  • 2858
  • bits
  • breakout
  • individual
