Memory requirements for converting to large numbers (Hex)
  • Memory requirements for converting to large numbers (Hex)
‎2018-09-07 01:21 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:09 AM
Memory requirements for converting access control to large numbers (Hex)
TAC INET
I/NET
When using HEX card numbers the SLI will reserve memory for all required cards.
The attached link will explain the memory requirements for the SLI using the Large (Hex) Number scheme.
SLI Storage Capacity.doc
  • TAC INET
  • 2502
