Maximum size the SQL database using MSDE?
  • Maximum size the SQL database using MSDE?
‎2018-09-06 10:55 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:52 AM
What is the recommended maximum size the SQL database can be using MSDE?
I/NET
What is the maximum size the SQL database using MSDE?
The MSDE server software distributed with I/NET Seven imposes a 2GB restriction on database size. Larger facilities, particularly those using image verification and/or AMT archiving, could potentially encounter data storage problems due to this restriction, and should consider upgrading to SQL Server 2000. Refer to TCON 300.
  • TAC INET
  • 1226
