Maximum number of local program variables can be declared in script program
  • Maximum number of local program variables can be declared in script program
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2022-12-08 05:06 PM
on ‎2022-12-08 05:06 PM
Is there any limitation for the number of local program variables that can be declared in a script program located in ExoStruxure BMS servers or BACnet/IP controllers?
  • Building Operation Automation Server
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
  • Building Operation Multi-purpose Controller
  • Building Operation Multi-purpose VAV
  • Building Operation Room Controller (RPC) 24 V
A script program has a lot of variables declared.
There are no hard limits imposed by the script compiler. for the number of local program variables. The limits are performance and device resources. The bigger a program is, the more memory and processor bandwidth it will consume and the longer it will take to execute.
  • MahmoudSayed22
