Maximum number of devices on the MS/TP trunk of ENC-520, UNC-520 and MNB-1000
  • Maximum number of devices on the MS/TP trunk of ENC-520, UNC-520 and MNB-1000
  • PeterEdvik
    PeterEdvik
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 12:42 PM
Last Updated: Janeway PeterEdvik Janeway ‎2023-04-18 05:46 AM
What is the maximum number of devices that can be placed on the MS/TP trunk of the ENC-520, UNC-520 and MNB-1000?
TAC IA Series
  • Niagara R2
  • Niagara G3
  • UNC-520
  • ENC-520
  • MNB-1000
Unit Load is a measure of the electrical loading of an EIA-485 (MS/TP) network. An EIA-485 network may have 32 unit loads. One unit load consists of one full-load transceiver, two half-load transceivers, four quarter-load transceivers, or eight eighth-load transceivers.
All MNB-xxxx, UNC-xxx, and ENC-xxx devices use quarter load transceivers, which mean that a MS/TP network comprised solely of MNB devices can have up to 128 total devices (1 router plus 127 controllers). The maximum number of BACnet devices allowed per MS/TP trunk, if all devices are quarter-load transceiver, is 127 plus the ENC/UNC or MNB-1000 controller.
Note: 32 unit loads times 4 transceivers per unit load equals 128 maximum transceivers per network (32 X 4 = 128).
UNC/ENC Resource Limit
Although the 128 BACnet devices is the stated maximum for a MS/TP trunk, this maximum is normally not achieved. This is because the number of MS/TP devices that can be placed on a MS/TP bus is limited by the resource limit of the UNC/ENC controller. A shortage of resources will limit the devices on an MS/TP network to a number less than the physical limit. Exceeding the resource limit will negatively affect the UNC/ENC-520s, possibly causing poor performance and resets (of the UNC/ENCs).
Reference Appendix A of BACnet Wiring and Networking Practices Guide for additional information.
  • TAC IA Series
Tags (2)
  • 7288
  • PeterEdvik23
