Max Close Off pressure
  • Max Close Off pressure
  • SESA150559
    SESA150559
‎2018-09-06 10:28 AM
How do I find the max Close Off pressure for a certain valve/actuator combination?
Valves
Actuators
The max defined Close Off pressure is important when choosing the correct valve/actuator combination for an installation.
The max Close Off pressure is defined in charts or graphs in each valve series data sheet.
  • Field Devices
  • 13055
