Manipulating the bits in a Wiegand custom card field.
  • Manipulating the bits in a Wiegand custom card field.
  • AbeMeran
    AbeMeran
‎2018-09-06 02:01 PM
How to reverse and/or complement the bits as read from a Wiegand access card in a custom card configuration
CyberStation
CX9702
CX9900
CX9680
ACX5720
ACX5740
ACX701
ACX781
Some Wiegand cards are encoded with the bits in one or more fields reversed and/or complemented. It is then necessary to operate on the fields when decoding the data in order to obtain the correct data.
In the AccessFormat array a control field is provided to configure the system so that the bits in a field in the access card data can be reversed and/or complemented.
The control mask is located at AccessFormat[2]
Control Mask
The bits of the control mask will be used by the parsing routine to reverse or complement selected fields. Setting the appropriate bit to a 1 will enable the special action:
Field
Issue Code
Card Number
Site Code
Manufacturers Code
Feature
Reverse
Complement
Reverse
Complement
Reverse
Complement
Reverse
Complement
Bit #
7
6
5
4
3
2
1
Bit Value:           128                64                  32               16                   8                      4                    2                  1
Examples:
To reverse the bits in the site code field set AccessFormat[2] = 8
To reverse the bits in both the card number and site code fields set AccessFormat[2] = 40
Reversing the bits makes the first bit in the field become the last.
Complementing the bits flips the bit's value, 1 becomes 0 and vice versa.
  • 4810
