Making changes in a personnel object from WebClient logs the user out with error.
  • Making changes in a personnel object from WebClient logs the user out with error.
  • AbeMeran
    AbeMeran
‎2018-09-06 09:47 AM
Making changes in a personnel object from WebClient logs the user out with the error:
Web.Client is currently unavailable, if the problem continues, contact your system administrator.
WebClient
The name of one or more areas attached to the personnel object contain non alpha numeric characters such as commas.
Remove offending character from area's name.
  • 15263
