MZ20 stroke length
  • MZ20 stroke length
  • SESA150559
    SESA150559
MZ20 stroke length
‎2018-09-06 09:42 AM
Stroke length specification is different in older vs newer documentation.
MZ20A
MZ20B
Different specifications depending on source.
The stroke is 8.5mm but it is a floating actuator. Some of the range will be limited by the stroke of the valve, there may also be a small pre travel to ensure close off.
  • Field Devices
  • 15591
