MVB46 actuator for V311T
  • MVB46 actuator for V311T
  • SESA150559
    SESA150559
‎2018-09-06 10:20 AM
Will a MVB46 fit straight onto a V311T valve?
Controlli / Satchwell MVB46
TAC Forta
Controlli actuator on Schneider Electric / TAC valve
The Forta series actuators are suitable for use on the V311T valve. The data sheet for V311T has the different size Forta actuators listed, depending on application requirements.
  • Field Devices
  • 13500
