MS41 SmartX Damper Actuator Replacement
  • MS41 SmartX Damper Actuator Replacement
  • DavidChild
    DavidChild
  • David_Kendrick
    David_Kendrick
Admiral David_Kendrick Admiral
‎2021-09-10 12:58 AM
Last Updated: Sisko DavidChild Sisko ‎2021-09-10 01:04 AM
Replacements for Schneider-Electric SmartX MS41 Damper Actuator
Field Devices
SmartX MS41
Replacement of SmartX MS41 Damper Actuators within the Schneider-Electric range
Outgoing Actuator Model          Replacement Model (Part Number)
      MS41-6083-G00                        MD10A-24 (875 1019 000)
      MS41-6153-G00                        MD20A-24 (875 1029 000)
      MS41-6153-G10                        MD20A-24 (875 1029 000)
      MS41-6153-G12                        MD20A-24 (875 1029 000) + Aux Switch (914 1061 000)
  • Field Devices
  • DavidKendrick21
