MR-VAV-AX output 3 set to an AO instead of a DO
  • MR-VAV-AX output 3 set to an AO instead of a DO
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 10:42 AM
MR-VAV-AX
This is correct. The output will always be labeled as an AO even thought the function of the output will be a DO
If a DO is required for additional programming needs, create an internal DO point and use either a calculation or event sequence to control the new internal point.
  • TAC INET
  • 12358
