MR-VAV-AX Damper Position not responding
  • MR-VAV-AX Damper Position not responding
‎2018-09-10 08:22 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:52 AM
Damper position and Valves do not respond to any commands that are sent to it.
MR-VAV-AX
The SPL setting on the device was set to 1650, this is a default setting but needs to be set to a correct value otherwise  the damper position would not function properly.
The chart below can be found in TCON147: ASC-VAV-AX Installation Guide, page 69. This shows what values need to be set for this to function.
Table 12. Shutdown/Purge/Lockout Values
S/P/L Value Mode Cooling Damper Heating Damper Auxiliary Heating
Fan Heat
0 to 99 Normal Modulating Modulating Cycling/On Cycling
100 to 199 Lockout - Heat Modulating Closed Off Off
200 to 299 Lockout - Cool Closed Modulating Cycling/Off Cycling
300 to 399 Lockout - Full Closed Closed Off Off
400 to 599 Purge CHF CHF On Off
600 and over Shutdown Closed Closed Off Off
  • TAC INET
  • 7085
