MNB-Vx download error "The download was completed but the application was invalid"
  • MNB-Vx download error "The download was completed but the application was invalid"
  • sesa119747
    sesa119747
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-07 02:24 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-11-04 08:39 AM
  1. The MNB-Vx appears in the Workplace Commissioning Tool in a read-only mode.
  2. After downloading a MNB-Vx controller, an error window appears stating "The download was completed but the application was invalid. The device is now running the factory default application".
TAC IA Series
  • MNB-Vx
  • Workplace Commissioning Tool
This condition is related to improper AC power provided to the MNB controller. Typically, when AC power drops below 20 Vac, the controller will fall back to a factory-installed application and switch to read-only mode in the Workplace Commissioning Tool.
  1. Fix the AC power supply so that it is within specifications for the MNB controller.
  2. Do a hardware reset using the dip switches to get it out of read only mode.
  3. Try the download again.
  • TAC IA Series
  • 3694
