MN-CI revision 4.1 returns an error 511 when sending a "Reset" command to a MicroNet 2000 controller.
  • MN-CI revision 4.1 returns an error 511 when sending a "Reset" command to a MicroNet 2000 controller.
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 02:08 PM
MN-CI revision 4.1 returns an error 511 when sending a “Reset” command to a MicroNet 2000 controller. The controller does reset as commanded.
MN-CI rev. 4.1 software, MN-FLO, MN-FLO3T, MN-HPFC
The problem is caused because MN-CI rev. 4.1 sends the “Reset” command twice, and temporarily loses communications with the controller.
The error is considered a nuisance and can be ignored.
  • TAC IA Series
  • 4603
