MF41 SmartX Damper Actuator Replacement
  • MF41 SmartX Damper Actuator Replacement
  • DavidChild
    DavidChild
  • David_Kendrick
    David_Kendrick
Admiral David_Kendrick Admiral
‎2021-09-10 01:07 AM
Last Updated: Sisko DavidChild Sisko ‎2021-09-10 01:07 AM
Replacements for Schneider Electric SmartX MF41 Damper Actuator
Field Devices
SmartX MF41
Replacement of SmartX MF41 Damper Actuators within the Schneider-Electric range
Outgoing Actuator Model         Replacement Model (Part Number)
     MF41-6083-G00                         MD10B-24 (875 1015 000)
     MF41-6083-G02                         MD10B-24 (875 1015 000) + Aux Switch (914 1061 000)
     MF41-6153-G00                         MD20B-24 (875 1025 000)
     MF41-6153-G02                         MD20B-24 (875 1025 000) + Aux Switch (914 1061 000)
  • Field Devices
  • DavidKendrick21
