MD10SR-TS power supply options/limitations
  • MD10SR-TS power supply options/limitations
  • SESA150559
    SESA150559
‎2018-09-06 12:36 PM
Which power supply options are specified on the MD10SR-TS actuator?
MD10SR-TS
The data sheet may be a bit unclear at some points regarding the requirements on which power supply that can be used on this Universal actuator.
AC 50/60Hz: 19,2-264 V
DC: 21,6 -137,5 V
  • Field Devices
  • 7454
