MBus to Modbus TCP
  • MBus to Modbus TCP
MBus to Modbus TCP
‎2018-09-11 06:27 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:50 AM
MBus to Modbus TCP
Andover Continuum, EcoStruxure Building Operation, Satchwell Sigma, TAC Vista
  • Mbus
  • Modbus
How to read MBus devices into a BMS System using Modbus TCP
There are different methods, but these are generally using a Modbus RTU / Mbus gateway and then converting it to Modbus TCP. The following ADFweb solution allows Mbus to be read directly into a Modbus TCP device.
Click here for the datasheet.
Labels (4)
  • Satchwell BAS & Sigma
Tags (3)
  • 15140
  • m-bus
  • PeterLarsen23
